Author Topic: Np208 to np205?  (Read 8686 times)
Offline Jakethesnake73
Np208 to np205?
« on: April 10, 2015, 09:40:25 am »
I want to switch my blazer to the old style transfer case, is that a direct fit or not?
Re: Np208 to np205?
« Reply #1 on: April 10, 2015, 09:00:59 pm »
No it will not be a simple matter of removal and replace.
Re: Np208 to np205?
« Reply #2 on: April 10, 2015, 11:05:34 pm »
what transmission do you have now?
Offline roundhouse
Re: Np208 to np205?
« Reply #3 on: April 13, 2015, 05:36:57 am »
You'll need a new crossmember
New driveshafts
New hole in the floor
And new Trans to t case adapter
Why you want to change It?
You breaking 208s?
Re: Np208 to np205?
« Reply #4 on: April 14, 2015, 07:45:02 pm »
New driveshafts
You breaking 208s?
just wanting to make my vehicles as reliable as possible but thats just too much changing around to be worth
Re: Np208 to np205?
« Reply #5 on: April 14, 2015, 08:59:32 pm »
theres nothing wrong with the 208. the military used them we have some guys who plow with them. if your mudding and really abusing the truck yeah think about the swap but besides that you will be ok
Offline fitz
Re: Np208 to np205?
« Reply #6 on: April 16, 2015, 01:50:36 pm »
  Like Irish said, the Military used them in many of the CUCV's. The M1008 & M1028 are basically K30's rated at 5/4 tons and they run a 208 behind a turbo 400.
  Years ago in my 88 jimmy I went through 3 tranny's, 2 rear ends, bent the front axle, and cracked the frame, but the 208 never skipped a beat.
Re: Np208 to np205?
« Reply #7 on: April 21, 2015, 06:34:55 am »
I run the snot outa 208s in my plow trucks. Have had a couple fail over the past 25 years, but everything gets worn out at some point. Only others I have broken were with big tires, & a heavy right foot wheelin the wee outa my Blazer.
Re: Np208 to np205?
« Reply #8 on: April 22, 2015, 09:28:23 pm »
big tires and a heavy right foot cause it? Guess i better stock up on them lol
Offline hatzie
Re: Np208 to np205?
« Reply #9 on: April 23, 2015, 06:04:14 pm »
We beat the crap out of NP208 & NP241 cases when I was plowing in the early 90's.
They have much lower low range gears than most other transfer cases.
From orbit on my Android.
Offline frotosride
    • WFO CONCEPTS
Re: Np208 to np205?
« Reply #10 on: April 23, 2015, 06:46:44 pm »
I beat mine like a read-headed ford especially this last snow season. I love the low range!! When I would park at work I would find the most rediclouse place just to beat it out of whatever hole I put in when it was time to go home. The only issue I have is its hard to shift at times especially getting into 4l..havent had a chance to investigate that.
