Author Topic: Brake lights not working right all of a sudden  (Read 4613 times)
Offline ackland3
  • Shade Tree Certified Mechanic
« on: April 10, 2015, 11:46:13 pm »
So my brake lights all of a sudden are only lighting up when I have the headlights on. Threw a new brake light switch on and no reaction ideas?
1985 K10
305
Re: Brake lights not working right all of a sudden
« Reply #1 on: April 10, 2015, 11:50:36 pm »
is it your brake lights or your running lights? do your turn signals work?
Offline empire848
« Reply #2 on: April 11, 2015, 12:03:01 am »
I have the same problem.
body lights turn on, but the brake lights wont turn on.
dang thing is killing me.
If I figure it out ill be sure to list it.
Offline ackland3
« Reply #3 on: April 11, 2015, 10:51:29 pm »
Found it it was the hazard light fuse. Apparently my stop lights run off of it as well.
1985 K10
305
Offline empire848
« Reply #4 on: September 04, 2015, 04:12:09 pm »
Hey,
Dont know if you solved your problem but I found on my truck there is a clip under the dash on the steering column. Connections were oxidized. You could try that.
Offline ackland3
« Reply #5 on: September 20, 2015, 08:19:16 pm »
Figured out the issue brake lights are wired into my hazards and the fuze was oxidized
1985 K10
305
