Author Topic: Need green filter for turn signal indicator  (Read 8398 times)
Offline jorwesflow
« on: April 13, 2015, 01:19:29 pm »
I've looked through   Trucks rockauto and classicparts.com but can't find this tiny little part. It's the green piece that acts as kind of a light filter for the turn signal indicator lamps. Any clue where else I should look?
Offline timthescarrd
Re: Need green filter for turn signal indicator
« Reply #1 on: April 13, 2015, 01:25:53 pm »
For an actual one, you'd probably only be able to get it at a scrap yard.  But it's just a piece of translucent green plastic, so you should be able to find something and cut it to the right size, or replace the bulbs with green LEDs
« Reply #2 on: April 13, 2015, 01:28:22 pm »
Post a picture of what you need.  I have a parts cluster, I may have exactly what you need and if I do, I will mail you one.
Offline jorwesflow
« Reply #3 on: April 13, 2015, 02:40:05 pm »
that little green thing
« Reply #4 on: April 13, 2015, 04:03:00 pm »
you need the other side then?
Offline jorwesflow
« Reply #5 on: April 13, 2015, 08:18:04 pm »
yep! much appreciated for even taking a look
