Author Topic: Removing Z-bar?  (Read 6195 times)
Offline Djones11
Removing Z-bar?
« on: April 13, 2015, 10:26:21 pm »
I'm in the process of removing my transmission on my 81 chevy 4x4 manual and I have everything off and ready to go except I can't seem to get the zbar off does anyone have any tips or tricks to get it off?
Offline overtime
Re: Removing Z-bar?
« Reply #1 on: April 14, 2015, 05:24:11 am »
There is a clip on both ends.  Once there off losen the rod that pushes against the clutch fork and it should be easy to remove.
Offline roundhouse
Removing Z-bar?
« Reply #2 on: April 14, 2015, 05:43:53 am »
There is a hex on the inside
Where it bolts thru the frame bracket
There is a nut on the outside and if you look close with a bright flashlight you will see a hex on the other end after it passes thru the bracket
You can slip a open end wrench on it to stop it from turning and then remove the nut on the drivers side of the bracket
Wish tapatalk would let me post pictures
« Last Edit: April 14, 2015, 05:54:43 am by roundhouse »
Offline Djones11
Re: Removing Z-bar?
« Reply #3 on: April 14, 2015, 04:42:30 pm »
I've got the nut off the frame side but that doesn't seem to loosen it or help at all
Offline roundhouse
Re: Removing Z-bar?
« Reply #4 on: April 14, 2015, 10:15:32 pm »
Its same on the engine side I think
