Author Topic: Dash Pad Fiber Glassing and Nexus 7 Install  (Read 28109 times)
Offline sphinx
Re: Dash Pad Fiber Glassing and Nexus 7 Install
« Reply #15 on: April 27, 2015, 10:11:32 pm »
Excellent job.  Any problems working with the fleece instead of fiberglass cloth?
« Reply #16 on: April 27, 2015, 10:51:02 pm »
heck of a lot better job than i could of done. good job
Offline bperri1
  • 1984 K20 6.2l NA Diesel
« Reply #17 on: April 29, 2015, 02:10:59 pm »
That came out great.
How many hours would you quess you have into the project?
For me, I would say a good 20 or more. I was pretty new to this stuff so it was all a learning process.
Offline bperri1
« Reply #18 on: April 29, 2015, 02:14:41 pm »
Imo the fleece is easier for this type of project because structural rigidity isn't as important since the dash pad provided this and the fleece stretches and is more forgiving around contours and edges. The cloth tends to be used more where it will be abused or need lots of strength. One thing I cant say enough though is to make sure you have the COMPLETELY SOAKED in resin. I learned from my mistakes.
Offline bperri1
« Reply #19 on: April 29, 2015, 02:22:12 pm »
The last couple days I have been trying to get all of the tech equipment hooked up. I ran into a few issues though. For some reason now that I have taken my previous radio head unit out of the picture, the amp for the 4 speakers has been iffy. First of all I run two amps, one for the sub and one for all four speakers. The sub amp and sub woofer work fine. When I start my truck and let it idle, the amp for the 4 speakers cuts out. ( i think it has a safety cut off) I was confused as i have never had this problem before. I did a test with a multi-meter and found that I am running 13.2v at idle. when I increase rpm, the amp comes back on and the voltage increases to about 13.4-5. My only conclusion is a alternator running down hill because I think its supposed to be around 14v. If any one has any input that would be awesome! Also, my truck is a diesel, so it has two batteries.
Offline sphinx
« Reply #20 on: May 01, 2015, 10:32:22 pm »
Although automotive electronics are "12 volt systems" the expected voltage is 13.8 volts on a properly functioning automotive system.  If the amp has overly sensitive voltage cutoff point, the power supply may be shutting down if the voltage drops too low.
Offline Trailnut
« Reply #21 on: May 15, 2015, 06:56:06 am »
Awesome  ;D
'73 Chevy,  C10,  LWB, 350 ci, 350 trans
Would rather push a Chevy than drive a furd!
Offline sneaux707
« Reply #22 on: August 22, 2015, 11:14:28 am »
Wow that turned out amazing, thanks for giving me another great project. Quick question for ya, in your photo with all the product used there is fiberglass mat did you end up using that or just the fleece. New to fiberglass and filler so any advice would be much appreciated. Thanks
Sent from my SAMSUNG-SM-G900A using Tapatalk
Offline bperri1
« Reply #23 on: August 22, 2015, 11:56:56 am »
Tha ks alot! I didn't end up using the mat. The mat is stronger than the fleece though. I bought just I case I had to fill any holes. Since I just covered the dash, the fleece was sufficient.
Offline Dr_Snooz
« Reply #24 on: August 22, 2015, 11:23:14 pm »
That looks excellent! Very nice!
Offline luketaylor0
  • 1982 Chevy K10 Scottsdale
« Reply #25 on: October 04, 2015, 11:12:20 pm »
that actually turned out very well, nice job!!
Offline SmokeShow
« Reply #26 on: May 09, 2016, 09:42:55 pm »
A POV shot from the driver's is needed! Good work!
Project: 1983 GMC K30 Crew Cab Short Bed, D60 front w/ LocRite Locker, 14BFF w/ Lincoln Locker, 4.56 Gears, NP205 Transfer Case mated to Muncie SM465.  Have 06 Duramax/Allison waiting to be installed
Driver: 2002 Chevrolet 2500HD EC SB D/A
Offline OldGray
  • Ne'er-do-well
« Reply #27 on: May 10, 2016, 10:19:46 am »
That is very cool.  Nice work!
1979 Chevrolet Bonanza / 305 / LWB
Offline COREY13
« Reply #28 on: August 08, 2016, 04:54:07 pm »
That turned out really great. Did you end up covering up the holes in the dash for the speakers? If you did, how did that affect sound?
Roll Tide
