Author Topic: will a (long) stepside bed fit on an '87 1 ton frame?  (Read 12153 times)
Offline kuribo
« on: April 28, 2003, 11:59:00 am »
Does anyone know whether or not there are any long stepside beds that would fit on a K30 '87 1 ton frame? Any help appreciated. Thanks.
Offline 79SilveradoK30
« Reply #1 on: April 28, 2003, 04:20:00 pm »
The only long box stepside beds I've seen were on early '50s Chev/GMC trucks, and few at that.
Offline kuribo
what is the difference between 3/4 and 1 ton frames?
« Reply #2 on: April 28, 2003, 07:10:00 pm »
I have seen aftermarket replacement long stepside beds for 1/2 and 3/4 ton 73-87 chevy trucks, but not for the 1 ton. What is different about the 1 ton frame as compared to the 3/4 ton?
Offline Snuke87chevy
Re: what is the difference between 3/4 and 1 ton frames?
« Reply #3 on: April 28, 2003, 07:46:00 pm »
I know a guy that had an 86 3/4 2wd longbed stepside.  It was dark green.  I also see one around campus (an 85-86) that has toolboxes mounted on the sides, and they look like a factory installed option.  Is a one-ton frame narrower than a 3/4?
Frame
« Reply #4 on: April 30, 2003, 05:53:00 am »
the frame is the same, The rearend on a cab and chassis is narower than a pick up or duelly. This in turn means your inner tires would rub the bed.
Offline kuribo
putting a long stepside bed on a 1 ton frame...
« Reply #5 on: April 30, 2003, 07:15:00 am »
So if I convert the dually rear by changing the hubs to a single rear, I will be able to put a 3/4 ton stepside long bed on the 1 ton chassis without any problems?
I am wondering if the wheelbase on the 3/4 ton and the 1 ton are different? If they are, it wouldn't work without shortening the frame or maybe moving the rear spring mounts????  Anyone know about this?  thanks!
« Reply #6 on: April 30, 2003, 04:38:00 pm »
I believe the wheelbase of a regular-cab long box 3/4-ton is that same as a similar 1-ton or 1/2-ton.
Rear
« Reply #7 on: May 01, 2003, 06:15:00 am »
If you put a step or fleet side bed on a dually truck the outside tires will stick out. If you put a bed on a cab and chassis the inside tire will rub the wheel well. The dually has the same width and the same hubs etc. as a single rear wheel 3/4 or 1ton. The rear of a cab and chassis is narrower in other words the backing plate is closer to the spring perch.
