Author Topic: Fuel pump selection  (Read 5140 times)
Offline sbx22
  • 1974 1/2 ton 350 sbc
Fuel pump selection
« on: April 19, 2015, 05:32:03 pm »
I need help selecting a fuel pump. I know about the GPH equation of (HP x 0.5)/6. I know my Holley needs 5-7 PSI. I found the Edelbrock Performer RPM mechanical fuel pump with 6 max PSI and 110 GPH. According to the GPH equation above for my setup, (330 x 0.5)/6 would only yield 27.5 gph. Huge difference between 27.5 and 110 GPH. Can someone school me on this? Will this flood the carb? My set-up will be return-less. Thanks.
Offline sbx22
Re: Fuel pump selection
« Reply #1 on: April 20, 2015, 12:24:11 am »
nvm, found a nice carter fuel pump 40 gph and 5.5-6.5 PSI part #CRT-M4685.
Offline jetmech
« Reply #2 on: April 20, 2015, 10:15:31 am »
Just because the Edelbrock is rated at 110 gph doesn't mean it will flood the carb. The carb will stop the fuel flow when the bowl is full and only allow fuel flow when needed. With that said, you will be fine with the Carter pump.
'86 Sub and '86 SWB C-10
1990 454 SS
Offline blazer74
« Reply #3 on: April 20, 2015, 05:59:02 pm »
Stay with a carter or delco, Stay away from over the counter replacements (off brands put out to much pressure.
Edl 110 would work fine but no need to spend that kind off money.
I have the Edl 110 pump on my 74 350. Puts out 5 - 6 psi but is overkill.
Offline sbx22
« Reply #4 on: April 20, 2015, 08:18:26 pm »
Thanks all!
