Author Topic: Delphi AD244 Alternator pinout  (Read 5274 times)
Offline frotosride
    • WFO CONCEPTS
« on: April 20, 2015, 04:43:31 pm »
So here is the issue. With the alternator wiring pigtail from the alternator there is a 4-pin connector. Only 3-pins are used, two of which got to the ECM. The third originally went to the C100 under hood connector and is labeled a pin "J" Engine on Signal (w/SBA). My question is what is this wire and does it play a part in my application of the 6.0l swap in my '87? Any info even if it is just a pin out for the alternator would be helpful. The only difference from the reference that I am using for the Pinout of this wire(LT1Swap.com) is the actual wire color but location is the same. I'm sure its likely just do to the year that the color changed. Thanks for any help.
Re: Delphi AD244 Alternator pinout
« Reply #1 on: August 12, 2015, 11:00:02 am »
Did you find the answer to this?
Look here for the pins on the alternator.   http://www.pirate4x4.com/tech/billavista/Wiring/Part2/
Offline frotosride
    • WFO CONCEPTS
« Reply #2 on: August 22, 2015, 09:26:49 pm »
I did but I still read the tech. . You are never to old to learn thanks for the article. I saved the link just incase I forgot by the time I actually am able to finish the swap
