Author Topic: Crate motor  (Read 3724 times)
Offline qmr55
Crate motor
« on: April 22, 2015, 09:34:34 pm »
What crate motor will bolt into an 85 c10? previously had a 305 in it.
Will something like this bolt right up to the mounts?
http://www.jegs.com/i/Blueprint-Engines/138/BP3550CTC1/10002/-1?parentProductId=
Recommendations?
Thanks guys appreciate it!
Offline travisr1988
Re: Crate motor
« Reply #1 on: April 22, 2015, 10:25:10 pm »
Any traditional small block will bolt in with no modifications, any big block will bolt in if you move the mounts forward. So yes the engine in the link will bolt in, however, I would look for one with a smaller cam for a truck. Speak with Rich on cams as he is very knowledgable and helpful.
1979 Chevrolet Silverado C20 rclb cammed 355/th400/4.10 - sold
1977 Chevrolet Custom Deluxe c10 rcsb stepside 355/th350/3.42
Vortec heads lunati cam edelbrock intake headers
Re: Crate motor
« Reply #2 on: April 22, 2015, 10:41:32 pm »
like said yes but 4k+ for that thing is a little out there
Offline FlatBlack77
Re: Crate motor
« Reply #3 on: April 22, 2015, 10:47:23 pm »
plus you dont know how well the rest of the drivetrain would hold up to a motor like that
Offline Dan75k20
Re: Crate motor
« Reply #4 on: May 13, 2015, 11:10:10 am »
You want torque not horsepower for a truck
Offline fxrsrider
  • '75 C10, 385ci, TH350, Positraction, 5" drop
    • pauldemarcostudios.com
Re: Crate motor
« Reply #5 on: May 16, 2015, 05:17:42 pm »
... as noted  ::)  you always have to consider the whole system when upgrading.  Just as an example, the link's fine print states "Does not include flywheel/flexplate."  You'll likely need to change your torque converter, open your transmission for modifications to accommodate the new power, new pumpkin gears (consider Richmonds), and axles...
...recent advice I got from a professional hot rodder....."the project is never finished until you sell it.
