Author Topic: Door lock  (Read 6515 times)
Offline Chisholmcody
Door lock
« on: April 23, 2015, 08:21:02 pm »
I recently switched my door skin and am now having a issue with the lock. When I go to unlock the door with a key the key feels like it's going to break when I turn it (doesn't unlock door). But if I push the handle to "open" the door first it unlocks fine. What could be causing this?
Sent from my iPad using Tapatalk
Offline BlackTomC
Re: Door lock
« Reply #1 on: April 30, 2015, 10:20:13 am »
I'd like to know the answer to this one as well, all the sudden, my rear barn door lock on my Suburban just wouldn't turn with the key to lock anymore... hosed it down with WD-40, sprayed it out, still nothing. And the keys work in all the other locks.
The bottom line has dropped
Re: Door lock
« Reply #2 on: August 12, 2015, 12:05:16 pm »
You might want to check your latching mechanism and grease it.
Re: Door lock
« Reply #3 on: August 12, 2015, 01:58:06 pm »
i know on my crew cab if i lock one of the rear doors sometimes i cant unlock it unless i pull button on the outside handle out just a tad and it will allow me to unlock it. havnt tore into it to see what the problem could be so i cant help you there
Re: Door lock
« Reply #4 on: August 15, 2015, 01:29:54 pm »
Should I just use like a lithim based grease? Or a graphite
Re: Door lock
« Reply #5 on: August 15, 2015, 01:32:13 pm »
imo grease tends to attract dirt. i like graphite, but cant for sure if dirt will stick to as bad as grease
Offline bd
Re: Door lock
« Reply #6 on: August 15, 2015, 03:48:52 pm »
Should I just use like a lithium based grease? Or a graphite
Use white lithium grease aerosol spray available from GM as Lubriplate Spray Lube 'A', or CRC 5037, or Permatex 81981, or 3M 08875, etc, to lube the latch mechanism.  Use dry graphite in the lock cylinder if it is totally clean, dry and in good condition; otherwise use Tri-Flow.
