Author Topic: 84 Crew Cab Roof Removal, need help with rear seam above rear window  (Read 15788 times)
Offline srodster
Don't ask why at the moment, but I need to get some help from someone that has removed the outside roof skin on an '84 Crew Cab.  I have cut all the spotwelds and the front is loose enough to lift up about 5 inches.  However, the seam above the rear window appears to have been reverse spot welded, or the seam are faced inward, or it slides into a groove......not sure.  Just need to figure the correct way to remove it.
I have some photos for reference.  The short seam along each edge at the back appears to be tack welded......., I haven't messed with it yet, as I hope someone can help.  Maybe someone has played around with one, and can provide advise.
Offline HAULIN IT
Cut the roof skin off from the rear corners along the back a 1/2" or so above the seam & get the roof out of you way then you can work on the seam from there. I would suggest metal glue for installing the new one. Lorne
Offline srodster
I noticed there is a narrow panel on the inside of the roof, (part of the inner skin) that is only maybe 9 inches wide, that runs from corner to corner across the back, and is spot welded into the top the back glass housing.  I was thinking of cuting those spot welds and removing that particular panel to expose the seam I need for the roof.
I have attached a couple photos of the panel.
Make sense?
Offline srodster
Ok, a little ambitous today.  I got the section cut out, so now I can access the "C" rail on the inside that has the spot welds to get to the seam above the back window.  Almost there......, job for next weekend.
Offline HAULIN IT
I guess I'm confused...Are you throwing that roof away or is that the donor one? That sure seems like a  bunch of extra work. Does your truck have a headliner? Lorne
Offline srodster
No, the piece laying on the ground is what I had to cut out from the rear inside to access the spot welds above the back window to remove the roof.  So, now I will cut the spot welds out on the "C" channel seam, and lift the roof off.  Then I will rhino line the inside layers of the roof and celing, and also install a sunroof with drain tubes that will be sandwiched by the panels.
Offline HAULIN IT
Based on the way you started this post & the fact that what you are doing makes NO sense to a guy that has changed many roofs leaves me guessing...So you cut a perfectly good roof off of a truck, cut some of the inside of the cab out all to install a sunroof & then are going to re-install the same roof skin...Is that what I'm making of this?
Hmmm, & to think...I went to the GM dealer & bought a new roof skin & installed it on my 4x4 truck to get rid of the sunroof installed by a previous owner...Guess thats what makes the world go 'round. Lorne
Offline srodster
Actually, there is more to it, but that was just the basics for what is allowed on this thread.  So, the good news, I will have it off this weekend, and then I can go ahead and actually put some acoustics barrier in it, like a sandwich to make it quieter too.
Any pointers on reattaching it, or if you have some photos, let me know.  I would love to see them.  Thanks.
Offline fitz
Did you cut the roof off of your truck to add a sunroof and sound deadening material?  Am I missing something?
Offline srodster
There is a little more, but those are the basics.  (I was bored, ha...)
I'll send photos when I reattach it, but would like to know what tricks others may have used to reattach....., Tig or Mig the inside seams?  I don't have a spotwelder.......
Offline fitz
Re: 84 Crew Cab Roof Removal, need help with rear seam above rear window
« Reply #10 on: May 06, 2015, 07:30:38 pm »
I would glue it like Haulin IT said
Offline srodster
« Reply #11 on: May 06, 2015, 08:25:01 pm »
Any particular brand or part number for it?
Offline srodster
« Reply #12 on: May 12, 2015, 09:06:23 pm »
Does anyone have experience with the 3M™ Panel Bonding Adhesive, 200 mL, 08115 used to adhere panels?  Or a similar one?
http://3mcollision.com/3m-panel-bonding-adhesive-08115.html
Offline HAULIN IT
« Reply #13 on: May 16, 2015, 02:31:07 pm »
Care to explain: "the basics for what is allowed on this thread"? This is so silly I can't help but ask. Allowed by who? Why?      I've not used the 3M brand. There are several companies on the market. The one I've always used is Fusor...it's in a dual cartige package like the one shown using the same gun I believe. There are different drying time formulas & I would advise you use a slower one for a roof that size, especially if it's warm/hot where your using it. On the sides where you don't have any good way to clamp the skin...use a self tapping screw w/ washer in a few of the holes you made taking off the original spotwelds. Lorne
« Reply #14 on: May 22, 2015, 08:17:15 am »
i think what hes implying was he plans on doing more but wants to create a new thread with a different title for his build
