Author Topic: need help asap on axles  (Read 10767 times)
Offline stretch86
« on: May 09, 2015, 07:56:02 am »
I have a 86 c10 suburban  and am wondering if a 14b will bolt up to truck its a 8 lug ff outta a 75 also wondering if axle outta 84 3/4 ton would bolt up and if front cross member will bolt up to my truck as ive put new front end parts on it or what itd take to swap it over to 3/4 ton reason i ask is cause ive found a complete rolling chassis for cheap
Re: need help asap on axles
« Reply #1 on: May 09, 2015, 08:45:40 am »
the 14 bolt is it out of the ¾ ton? the frames between the ¾ ton and ½ tons are identical except for the thickness and its only a small amount so you can swap all the front parts over. is the donor truck also a burb? i know theres a difference in 2wd trucks vs 4wd as far as the center hump goes idk about burbs and you might have to make room for the transfer case to fit either body lift or swapping center. but you might not even have to worry about that, have to wait till someone who knows can answer
Offline stretch86
« Reply #2 on: May 09, 2015, 01:55:33 pm »
There both 2wd the front cross member that hold the engine and control arms is a lil tender on my suburban and the rear end is junk cause spider gears are chewed up and its a gov lock dif
« Reply #3 on: May 10, 2015, 07:11:19 am »
Use this for the u-joints you might have to measure your old u joints but report back with what yours have and ill try to make a reference chart for others. the 14 should pretty much be a direct swap. are you swapping springs also?
Offline stretch86
« Reply #4 on: May 10, 2015, 11:20:37 am »
If the springs are a direct swap i probably would as it wouldnt hurt to plus i plan on towing my pop up and a utility trailer with it the guy said hed do 250 for the complete chassis and said it was fine if i pulled the diff cover to inspect gears is the front end a direct swap cause i plan on taking the front cross member out to replace mine as its a lil tender and this truck is from California
« Reply #5 on: May 10, 2015, 11:44:34 am »
its a direct swap. the front can swap with the crossmember might be able to do it with out idk hopefully someone else can help out. count the number of springs in the rear cause they might have the same amount and the springs between ½ and ¾ ton are the same its just the number of springs that makes a difference
Offline stretch86
« Reply #6 on: May 10, 2015, 01:36:55 pm »
What do you mean by this "the front can swap with the crossmember might be able to do it with out idk"
Offline stretch86
« Reply #7 on: August 11, 2015, 08:09:38 pm »
How much wider is a 86 k20 9.5 14 bolt then my c10 10 bolt and will it bolt up to my suburban
Offline roundhouse
« Reply #8 on: August 11, 2015, 10:54:49 pm »
Should bolt right in
Offline stretch86
« Reply #9 on: August 12, 2015, 12:45:07 pm »
How much wider is it then the 10 bolt
Offline roundhouse
« Reply #10 on: August 13, 2015, 06:59:47 am »
Impossible to say
Are you referring to the spring pad or to the wheel mounting surface ?
They made several variations
SIngle rear wheel.  Dual rear wheel.  Drum brake.  Disc brake
Cab & chassis
All are different widths but not enough to worry about except the dual rear wheel models
Maybe same width.   May be two or three inches wider
The stock 10 & 12 bolts make the truck look funny since they are for some reason, several inches narrower than the front axles
« Last Edit: August 13, 2015, 07:01:53 am by roundhouse »
Offline stretch86
« Reply #11 on: August 13, 2015, 11:46:46 am »
The 14 bolt is sf outta 86 k20 pick up and my 86 suburban  is 2wd
« Reply #12 on: August 13, 2015, 12:26:56 pm »
i really dont think theres any difference in the axle widths as long as theyre swr. there is a difference in the widths of the front axle compared to the rear and some say this is for "tracking"
Offline stretch86
« Reply #13 on: August 13, 2015, 05:00:18 pm »
If i get this rear end  what u joint will i need
« Reply #14 on: August 13, 2015, 09:25:50 pm »
Universal joint conversion part numbers
This one should be the part number from Napa to make the c10 burbs driveshaft fit the 14 bolt if its wrong tell me
NPJ P447
