Author Topic: 1973 c10 (far from perfect 10)  (Read 18516 times)
Offline Car10s
  • I love the garage
Re: 1973 c10 (far from perfect 10)
« Reply #15 on: May 27, 2015, 12:10:35 pm »
Great question. I ordered a k5 blazer tank and it is huge. I really think I ended up with a suburban fuel tank but I am sure I can make it work. That is the next step. I really want to make the fill hole behind the license plate. We will see.
Floor IT!!
Offline RAD77C10
« Reply #16 on: May 28, 2015, 02:45:11 am »
You've got alot done, in a short amount of time!
Offline Car10s
  • I love the garage
« Reply #17 on: May 28, 2015, 12:22:06 pm »
I love this stuff 8)
Floor IT!!
Offline Car10s
  • I love the garage
« Reply #18 on: June 01, 2015, 09:38:25 pm »
This was a 4.3v6 truck and even though Google search affirmed that the frame perches would work for the 350 that was not true. I fabbed mine up using 3/16" 4" strap steel drilled and re welded to the perches. I also had to trim off some of the perch tabs.
Floor IT!!
Offline Car10s
  • I love the garage
« Reply #19 on: June 01, 2015, 09:45:00 pm »
Engine and trans went in easier than I thought. I was expecting to run into trouble with the sump oil pan and I did. Not too shabby. Excuse the dirty firewall, I had to mount the cab to set in the engine. I will remove the cab and clean her good.
Floor IT!!
Offline Car10s
  • I love the garage
« Reply #20 on: June 01, 2015, 09:50:07 pm »
I set the engine as far back as I could leaving room for the huge hei distributor. Set the angle at 0 side to side and -3 degrees back. This leaves the tail of the tranny at -6 degrees.
Floor IT!!
