Author Topic: Welding in glass packs?  (Read 7556 times)
Offline Jakethesnake73
« on: May 10, 2015, 03:38:09 pm »
Im gonna get some thrush glass packs and i know that with exhaust clamps you want the flow coming from a male end and into a female end to help prevent leaks. Is this necessary if i weld a sealed weld?
Offline FlatBlack77
Re: Welding in glass packs?
« Reply #1 on: May 10, 2015, 05:05:54 pm »
it isnt exactly necessary but it would probably help exhaust flow a tiny bit.
but if its easier to do it the other way and it would be a huge hassle to get things flipped around or whatever then i would just not worry about it and weld that bad boy up
« Reply #2 on: May 13, 2015, 07:23:16 pm »
male to female helps prevent turbulence but most times its nothing its nothing unless you want to make your exhaust as free flowing as possible or at least thats what im thinking
Offline Stewart G Griffin
« Reply #3 on: May 13, 2015, 08:56:26 pm »
Yes, i'm also thinking it won't make much a difference especially that far back.
i also feel welding is better than clamps.
Offline FlatBlack77
« Reply #4 on: May 13, 2015, 10:19:25 pm »
when i did my duals i left the header collectors/reducers unboltable and i clamped the mufflers. then welded all the other pipe together. that way i can swap out mufflers if i didnt like/get tired of 8 inch cherry bombs
