Author Topic: Fuel pump replacement 1977 C10 350  (Read 4421 times)
Offline Flycast47
« on: May 11, 2015, 10:30:55 am »
I am replacing the fuel pump on my '77 C10 350 V8.  I purchased a Delphi MF0001 which is supposed to be the correct replacement for the AC Delco 40987 model. I installed the pump but it would not work - no fuel flow.  I returned the pump assuming it was defective and installed the new one with the same result - no fuel flow.  In comparing the Delphi pump to the original it is apparent that the rocker arm is shaped differently and not as long.  The push rod appears to engage the rocker arm during installation.  Has anyone experienced a similar problem with a Delphi or other replacement pump?
Offline enaberif
Re: Fuel pump replacement 1977 C10 350
« Reply #1 on: May 11, 2015, 10:34:39 am »
While it may appear to engage the rocker arm it may not. Put a small dab of grease on the end of the push rod and it will stick up inside the block so you can install correctly.
Also take into consideration the push rod IS a wear item and the same with the cam side.
Offline Flycast47
« Reply #2 on: May 18, 2015, 01:43:13 pm »
Rest of the story... I returned the second Delphi pump and got an Airtex with a rocker arm that is identical to the original.  Installed the Airtex pump and could still not get fuel to the carb.  I tried both tanks with no luck.  Enlisted an assistant had them crank the engine while I placed my thumb over the inlet hose on the pump to verify it was pulling a vacuum - it was.  Performed a fuel line test by blowing through the line back to the tanks and discovered that regardless of the fuel tank switch position the air only went to the right side tank.  Question, does the fuel tank selector valve only operate when the engine is running?  All this time I new that the right tank was very low on fuel but did not think it was empty - well it was.  We put abut 2 gallons in the right tank and, behold, the pump pumped and the engine started!!  Now, of course, I wonder if the Delphi pumps were working the whole time.  A point that I would like to make is to validate comments made by other folks on the fuel pump replacement process regarding the retention of the pushrod during installation.  That is, the best way to do it to use a longer bolt in the access bolt hole.  That way you can be absolutely sure the rod stays in place during the entire process.
