Author Topic: removing 4" lift and going to stock height?? '83 k10  (Read 18343 times)
Offline BBM3
Re: removing 4" lift and going to stock height?? '83 k10
« Reply #15 on: June 11, 2015, 06:27:14 pm »
as long as its not binding you will be ok. i run 6" on a sm465 so my angle is greater than that and i been running that for years. not to mention everyone else with a stick shift. i mean if you want to go back to stock then have at it. i just dont want you to think something is wrong with a setup
It's all good.
Just pointing out that I think the OP may have been referring to U-joints rather than ball joints.
« Reply #16 on: June 11, 2015, 07:51:09 pm »
no i understand didnt mean that for you but the op
Offline 87project
« Reply #17 on: June 11, 2015, 11:12:13 pm »
I have two stock front springs u can have... where are you?
