Author Topic: 1978 Chevy C20 Truck - Radiator Search  (Read 6228 times)
Offline El Capitan
« on: May 14, 2015, 12:39:09 am »
Hello everyone. I'm looking to purchase a radiator for my C20 but with so many options online I'm hesitant to pull the trigger. Any recommendations ?
They range from $98 to $350...
Offline fxrsrider
  • '75 C10, 385ci, TH350, Positraction, 5" drop
    • pauldemarcostudios.com
Re: 1978 Chevy C20 Truck - Radiator Search
« Reply #1 on: May 16, 2015, 05:07:38 pm »
My '75 C10 had an OE Camper Special radiator in it when I bought the truck (less than a year ago).  The Camper Special is big...and provides excellent cooling.  The rad fit my C10 perfectly.  With all the work I've been doing under the hood...I kept springing leaks.  Rather than send it in for another repair or recore, I opted to replace the OE with an all aluminum equivalent.....(some people will insist that the OE brass rads are better than the aluminum construction rads....others will argue that the aluminum rads are better.....my radiator guy says its a 50/50 split, depending on how clean you tend to keep your system..........One point that has never been disputed is that the Camper Special radiator is a great rad for the SBC and that the size and fitment is great for our Rounded-Line trucks.)
I just bought a 100% American Made, all Aluminum 4-core, Camper Special equivalent for $280 from my radiator shop here in L.A......it fit like a glove and cools like a champ.
Offline CA Big Red
    • Big Red Squarebody
« Reply #2 on: February 24, 2018, 08:07:36 pm »
I wanted to jump in here to see if I could get some ideas on why NAPA sold me a radiator that was two inches too tall after I spec’d out the truck, 350 motor, K10, etc. and this thing doesn’t fit.
"You don't know what you don't know."
1978 Scottsdale Stepside
383 w/ 4" lift & 35" BFG
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #3 on: February 24, 2018, 08:52:40 pm »
To the OP, anything would work, just make sure to match core size to current radiator. I would opt to a brass/copper or all aluminum over plastic tanks-last two plastic tank radiators I had leaked at the seams....
To CA big red, it is possible your radiator or engine was replaced....plus there are two core sizes avalable. 17" tall, and 19" tall. Sometimes certain options would call for the bigger radiator.
 1986 Chevy K30(under repair)
Offline CA Big Red
« Reply #4 on: February 24, 2018, 10:12:15 pm »
Thanks. I’ve got the 19” I should have measured when I picked it up. I was too excited to get it home after they said they had one.
« Reply #5 on: February 25, 2018, 11:22:50 pm »
i know pepboys had three and it took me three different times to get it right. first time was my mistake, second one again my mistake measured wrong part
