Author Topic: problems with flip kit axle relocators  (Read 6791 times)
Offline Car10s
  • I love the garage
« on: May 16, 2015, 09:28:00 am »
I bought the flipkit/relocators from a seller on ebay. They are the basic type that are made out of flat stock.
My problem is that they allow over 2" of axle rotation. all Flip kits I have ever installed lock the axle tube between the spring perch and the leaf spring and there is never movement. Is this normal? I have included a couple picks thank you
Car10s
this shows how the brackets leave a gap that allows the axle to rotate
flip kit
Floor IT!!
Offline hobbz
Re: problems with flip kit axle relocators
« Reply #1 on: May 16, 2015, 01:40:43 pm »
This is what the ones I used look like.
1987 Chevy R10 Short/Step -  350/th350
Build Thread
Offline HAULIN IT
« Reply #2 on: May 16, 2015, 02:18:03 pm »
Exactly! This is unfortunately one of those: "Ya' get what you pay for". I really wouldn't trust that even if it went all the way up to the old perch due to the uprights having no support. I'm not a big fan of Flip Kit design in general due to the added "moving around" part & leverage, however if you're going to do one, I'd suggest something like hobbz posted. My Two Cents, Lorne
Offline Car10s
  • I love the garage
« Reply #3 on: May 16, 2015, 08:35:07 pm »
I ended up doing what I have done in the past. I went down to the tractor supply and bought some spring heavy duty spring perces and drilled another hole 1" forward. I will set the pinion angle and weld them up. It looks like the seller will take back the flip kit. I refuse to use it with all that axle rotation
Floor IT!!
