Author Topic: Whay size exhaust clamp  (Read 7771 times)
Offline Jakethesnake73
« on: May 25, 2015, 05:27:07 pm »
I have 2.25" od exhaust and need to know what size exhaust clamp to use when clamping on a muffler that slips over the exhaust piping
Offline FlatBlack77
Re: Whay size exhaust clamp
« Reply #1 on: May 25, 2015, 05:41:53 pm »
you could probably use a 2.25 clamp. i would imagine a 2.50 would be too big but i could be wrong
one trick i use when clamping on mufflers/exhaust pipe is clamp it down real tight then loosen it back up and spin the clamp around 180 degrees so its opposite of where it was then tighten it up real good again and leave it there.
it kinda crimps the exhaust pipe the whole way around if you get my meaning
« Last Edit: May 25, 2015, 05:43:42 pm by FlatBlack77 »
« Reply #2 on: May 25, 2015, 07:42:45 pm »
i was thinking ill just clamp it down and use muffler sealer material to close up the end like you would with caulk on a house window
Offline enaberif
« Reply #3 on: May 26, 2015, 08:14:04 am »
Muffler sealer is junk. If the pipe slides into the muffler the clamp will be fine.
