Crew Cabs
Brake Lines for 1991 V3500
Topic: Brake Lines for 1991 V3500 (Read 27242 times)
Crimsontide14
May 25, 2015, 08:44:32 pm »
I am in the process of putting a lift on my 1991 Chevy V3500. While installing new brake lines to accommodate the lift, I damaged some of the factory brake lines. The original brake lines are pretty rusty and brittle. At this point, I am considering replacing all of the factory brake lines. Is there a company that makes good quality pre-bent brake lines for these trucks? Or am I better off buying the tools necessary and fabricating my own?
LTZ C20
Re: Brake Lines for 1991 V3500
May 26, 2015, 02:53:53 am »
There are a few companies that offer pre bent steel lines.
LTZ Cheyenne C20
roundhouse
May 26, 2015, 06:03:16 am »
I'd buy the pre bent ones if you can find em
Crimsontide14
May 26, 2015, 10:15:14 pm »
I have tried searching for a brake tubing kit for the V3500's but have come up short. Will the kits for the pre-88/K30 trucks work on the later V3500's?
LTZ C20
May 27, 2015, 12:39:47 am »
As far as I know yes they should, not sure tho. A K30 and a V3500 are the same thing, GM just changed the model coding (C/K or R/V) in the late 80s.
LTZ Cheyenne C20
May 27, 2015, 08:00:09 pm »
dont know when but gm did have some trucks with RWAL. dont know if its only on the 88-98 models or if our trucks have it
ehjorten
June 01, 2015, 02:04:55 pm »
You couldn't get RWAL on a 1-ton.
-Erik-
June 02, 2015, 01:22:05 am »
i remember a manual when i was working on my 91 crew cab it said something about rwal
87max
June 07, 2015, 04:09:57 pm »
inline tube has what you want. I got mine in stainless from them.
88 R30 lb7 transplant in progress
04 E350 6.0 studded & tuned work van
98 Taurus beater
Jim_Hensley
February 09, 2016, 01:12:02 pm »
Its not RWAL its a load sensing valve that applied more pressure to the rear wheels the heavier the load in the bed , starting in 87 I think.
87max
February 24, 2016, 01:03:32 pm »
yes its a load sensing valve & from what ive read that valve can be tossed without issue, mine will be going in the trash.
98 Taurus beater
February 24, 2016, 01:09:12 pm »
there was so many problems with the sensing valve that gm even said to toss it if there was any problems with the rear brakes
Crew Cabs
