Author Topic: Rear end in my 76 seems sloppy  (Read 2646 times)
Offline Kimper
  • NP203
« on: May 27, 2015, 08:22:43 pm »
I just inherited a 76 K10 and the 12 bolt rear ended seems sloppy. When i get on the gas after letting off I hear a clunk. When I grab the driveshaft I can turn it about 40 degrees in either direction and the U joints all seem to be tight. When I talked to the guy to gave it to me he said that him and the guy who restored it went through the rear and and everything seemed good so they didn't do anything except clean it up. What do you guys think, should I bring it to a specialist?
You shut your mouth when you're talking to me!!!
Re: Rear end in my 76 seems sloppy
« Reply #1 on: May 27, 2015, 08:37:29 pm »
check your trans mount. u joints may appear to be good but inside theyre toast
