Author Topic: how in the heck do I tension my power steering???  (Read 7603 times)
Offline CarlBengston
« on: May 28, 2015, 09:55:13 pm »
1983 k10, 350 goodwrench crate motor. Removed all of my ac components, and apparently the compressor was tensioning my power steering. So now I have no power steering. I understand that these trucks use a dual slot tensioner but the one next to the manifold I can't get to. The nuts is basically touching the manifold..... I don't have big enough arms to turn manually....
Re: how in the heck do I tension my power steering???
« Reply #1 on: May 28, 2015, 10:02:58 pm »
put a box end wrench on the bolt then use another wrench similar in size and use that second one's box end and link the two wrenches together and use it as leverage like this picture
it can sometimes be tricky to set it up, but it works
« Reply #2 on: May 28, 2015, 10:28:01 pm »
A Thexton #383 P/S pump tool helps provide the needed leverage to adequately tighten the belt too, without damaging the reservoir.
« Reply #3 on: May 28, 2015, 10:29:47 pm »
wow, never seen nor heard of this contraption. would of saved a lot of head ache
« Reply #4 on: May 29, 2015, 11:45:46 am »
That thing is cool! But my problem is that I can't get to one of the bolts to loosen it..
Offline fxrsrider
  • '75 C10, 385ci, TH350, Positraction, 5" drop
    • pauldemarcostudios.com
« Reply #5 on: May 29, 2015, 11:51:47 am »
You can also search for "AC Idler Pulley" or "AC Compressor Removal Pulley".....there are many depending on the block and application.  They look something like this (below) and just act as a place holder/idler in place of the removed compressor.
« Reply #6 on: May 29, 2015, 12:56:35 pm »
Any possibility of posting a pic or two, so we can get a better idea of exactly what you're facing?
« Reply #7 on: June 02, 2015, 08:02:23 pm »
Since there has been no reply, consider whether a long 9/16" combination wrench will work, such as a Snap-On OEXL 18B (pictured below).
