Author Topic: What size gas tank  (Read 9742 times)
Offline Jakethesnake73
What size gas tank
« on: May 31, 2015, 10:05:47 pm »
Not sure if this is the right place to put this but i was wondering what size fuel tank in in a 1987 blazer tbi 350, it has a rear mount tank.  One of the baffle spot welds has stressed and leaks. Also could this be causing a stalling issue when tank is low due to lack of fuel pressure or something
Re: What size gas tank
« Reply #1 on: May 31, 2015, 10:19:02 pm »
should be a 25
« Reply #2 on: August 17, 2015, 07:26:57 pm »
25 or 31 gallon...
« Reply #3 on: September 24, 2015, 03:12:02 pm »
Close up- 25 gallon
« Reply #4 on: September 25, 2015, 08:02:16 am »
It being loose shouldn't cause any stalling unless it is REALLY empty.  You can run EFI pumps in a non baffled tank as long as you don't run it less than about 3-5 gallons or so..  Even then it will stall on a baffled tank.  My Suburban has done this a few times on some big hills in turns and it is EFI and baffled.
