Author Topic: Rear end bouncing hard when tires lose traction..  (Read 3935 times)
Offline jdubya85c10
« on: June 07, 2015, 04:51:48 pm »
So I've wondered what causes this in my case. I believe it's called axle hop but not sure. If I stomp it sometimes the backend starts bouncing hard, my truck is lowered the owner before me torched leaf spring mounts and Re welded under axle. Truck drives straight and handles ok.
Offline smcgillis10
Re: Rear end bouncing hard when tires lose traction..
« Reply #1 on: June 07, 2015, 07:17:37 pm »
Probably exactly what you're thinking it is. You'd benefit from com traction bars.
Offline roundhouse
« Reply #2 on: June 07, 2015, 07:34:11 pm »
A traction bar will help
They  are available that don't hang down
You'll snap
An axle shaft with wheel hop
