Author Topic: Buzzer won't shut off!  (Read 3429 times)
Offline IdahoMan
« on: June 07, 2015, 08:51:55 pm »
Well, without any warning or cause, my the buzzer under my dash has turned on and won't shut off.
If the key is in the "half-start" forward position it goes off, but anything other than that and it won't shut off. Door open or closed, it's still on. It did this once before. I found out about it by going outside and hearing something. I have the battery disconnected right now.
What should I do?
Thank you.
IM
Re: Buzzer won't shut off!
« Reply #1 on: June 07, 2015, 10:04:04 pm »
Is the seat belt light on in the dash?  Does the buzzer stop singing when you unplug the turn signal switch?
Offline IdahoMan
« Reply #2 on: June 08, 2015, 03:21:10 pm »
Reconnected the battery this morning and it isn't doing it now.  ???
Update: It was fine all day, but this evening I went out and heard it again. disconnected and reconnected the battery and it shut off.
« Last Edit: June 09, 2015, 03:52:16 am by IdahoMan »
