Author Topic: Why bother..  (Read 6161 times)
Offline IdahoMan
Why bother..
« on: June 11, 2015, 03:29:05 pm »
Screw it!
I'll just pay hundreds of dollars to some punks at a bodyshop to do ANYTHING that involves painting from now on.
I go through hours of trouble trying to do it right: Scuff it, buy expensive cleaning/prepping chemicals, follow the self-etching primer and paint directions to.  the.  letter. And what do I get??? A year later and a little piece of tape peels the paint right off!! As if I rubbed the metal in olive-oil before I painted it.
Backstory: Tried to paint some camper mirrors black.
Offline Jason S
Re: Why bother..
« Reply #1 on: June 11, 2015, 03:35:50 pm »
Stainless steel camper mirrors?
Re: Why bother..
« Reply #2 on: June 11, 2015, 03:49:35 pm »
I hear you.  Not all etch primers are created equal.  Was the failure down to the substrate or was in intercoat adhesion failure?
Re: Why bother..
« Reply #3 on: June 11, 2015, 04:10:36 pm »
paint isnt easy or everyone would be doing it
Offline fitz
Re: Why bother..
« Reply #4 on: June 11, 2015, 04:45:44 pm »
Screw it!
We have some great body guys on  this site  that are always offering FREE advice.
I'm not so sure we will hear from them on this one.
Re: Why bother..
« Reply #5 on: June 11, 2015, 04:54:44 pm »
Harold should help, if he gets online ::)
Re: Why bother..
« Reply #6 on: July 15, 2015, 05:31:00 am »
In order for any coating to stick it needs a mechanical bond. If the mirriors are stainless steel no matter what the product it will have a tough time sticking.
Sand blasting, or grinding is the only way to prep stainless. Then prime with a high quality self etching, then a urethane primer to fill the grind, or sand blast marks.
Then sand the primer with 400 grit paper to achieve the mechanical bond for your top coat.
If going over old paint sand blast to remove, then follow above instruction. Or if paint is in great shape just sand with 400.
