Author Topic: rear end help. 73-87 88-99 99-06 widths  (Read 85794 times)
Offline stretch86
« on: June 11, 2015, 08:26:19 pm »
I have a 86 c10 suburban  and the rear end is junk im rebuilding it as i go. I was wondering if anyone knows the width (wms-wms) of the 10b,12, 14b sf and 14b ff for each set of years. I know ill have to move modify spring perches and shock mounts. I know where i can get a 00 chevy 1500 rear end its a 8.6 10b with disc brakes and was wondering how much wider it is. Only thing ive found is that the 88-98 is wider then 73-87 years and the 99-06 is wider then 88-98. I also found out that the 2wd are narrower then the 4x4.
Re: rear end help. 73-87 88-99 99-06 widths
« Reply #1 on: June 11, 2015, 09:25:02 pm »
Don't rule out full sized GM Caprice if you can do the welding.  I've heard they will work as well.
Offline stretch86
« Reply #2 on: June 11, 2015, 09:59:52 pm »
I cant weld but know people that can its just i cant find a rear end for truck thats usable and bolts in
« Reply #3 on: June 11, 2015, 11:44:59 pm »
I have one if your around Chicagoland, NW Indiana.  It is from a 86 C10 I parted out.
Offline blazer74
« Reply #4 on: June 12, 2015, 12:25:55 am »
You should have a 10b, you can measure,  12 bolt approx 63,  14sf 6 lug 2wd approx 65,  4wd    approx 68,             14sf 8lug ?,  14 ff ?
Offline stretch86
« Reply #5 on: June 12, 2015, 06:45:18 am »
Are those widths for 73-87
Offline stretch86
« Reply #6 on: June 12, 2015, 10:24:52 am »
What id really like to know is how wide the 88-98 14b sf is both 2wd and 4x4 if anyone has one that they can measure
Offline blazer74
« Reply #7 on: June 13, 2015, 12:20:42 am »
that would be 65" for 2wd and 68" for 4wd. I have both and have measured them both wms to wms. You will need to move the spring perches to match yours.
You will want the 2wd version.
« Last Edit: June 13, 2015, 12:26:05 am by blazer74 »
Offline blazer74
« Reply #8 on: June 13, 2015, 12:24:29 am »
The 14sf also have 1350 u joints. You will need a conversion u joint and also I believe the 14 sf is about an inch longer at the yoke iirc, so you may or may not run in to drive shaft length trouble.
Offline stretch86
« Reply #9 on: June 13, 2015, 07:18:09 am »
Ill be getting some measurements of mine. I was thinking about measuring yoke to axle center yesterday as i had almost forgot that itd be different. I know i have two drive shafts but does anyone know if the rear one on rear end is a slip shaft
Offline blazer74
« Reply #10 on: June 13, 2015, 04:11:25 pm »
SF also has larger studs on the axles,  14 mm.
Offline Stewart G Griffin
« Reply #11 on: June 14, 2015, 12:42:47 am »
How much are you willing to spend and how far are you from Pennsylvania?
Offline stretch86
« Reply #12 on: June 14, 2015, 07:04:13 am »
Im in nh
« Last Edit: June 14, 2015, 10:56:29 am by Stewart G Griffin »
« Reply #14 on: June 14, 2015, 08:03:44 am »
BTW, i think there is one in Weare for $150.
