Author Topic: 32 spline input shaft for NP208  (Read 6275 times)
Offline blueberrymuzik
« on: June 15, 2015, 02:35:59 pm »
I'm looking for a 32 spline input shaft for a NP208. My transfer case is dying on my '85 K20. I found a good core with a 27 spline input, but haven't been able to locate a 32 spline shaft to go in it.
« Last Edit: June 16, 2015, 10:13:06 am by Irish_Alley »
Re: 32 spline input shaft for NP208
« Reply #1 on: June 16, 2015, 10:12:45 am »
what about the one on your 208? i know it would mean more down time but it will be cheaper
« Reply #2 on: July 15, 2015, 05:44:24 am »
I would swap the one out of your old case.
If not Transtar should be able to hook you up. I know they have a place in I think Merrimack N.H. Pretty sure they have other locations around the country.
Just a thought, if your going to tear the new case all  apart to swap the input, you might as well rebuild it with new bearings, bushings, & chain.
If your going to do that, why not rebuild the one that's in your truck?
