Author Topic: engine removal  (Read 3963 times)
Offline Boxchevrolet
engine removal
« on: June 16, 2015, 09:25:35 pm »
hello im removing the 350 in my 1983 k10 4wd with a sm465 to put in a 305 i just rebuild because the 350 needs a rebuild, I've taken all the accessories off the engine and the exhaust manifold, carb, distributor, and starter, besides the motor mounts and bell housing bolts , is there anything I'm leaving out, I'm mostly concerned about the clutch and such, also any tips or tricks are gladly welcomed. thank you
Offline Don5
Re: engine removal
« Reply #1 on: June 16, 2015, 09:39:55 pm »
Did you remove the fan and water pump? You will have to pull the engine forward a little for the clutch/pressure plate to slide out of the input shaft on the transmission. I would highly recommend you replace the clutch, pressure plate, throw out bearing and pilot bushing before installing the new engine.
Re: engine removal
« Reply #2 on: June 17, 2015, 12:51:41 am »
ive removed the fan, I'm removing the radiator tomorrow
Re: engine removal
« Reply #3 on: June 17, 2015, 07:18:09 am »
ground strap on the back of the passenger side head
Re: engine removal
« Reply #4 on: June 17, 2015, 12:45:43 pm »
thankyou, is there any thing else ill run in to?
