Author Topic: 83 Silverado turn signal assembly question  (Read 10050 times)
Offline Ngs1022
« on: June 19, 2015, 01:02:41 am »
This part, which i need help naming and finding online to replace is in the steering column obviously and it moves when you flip the turn indicator right and left....its broken so my turn signal is useless. As you can see the previous owner tried to glue it to fix the cracking...Pics below...can you please tell me what its called that is broken on mine and who sells it? It is white and plastic i think, havemt taken the steering wheel off yet to get it out. Thanks a ton!
« Last Edit: June 19, 2015, 01:09:53 am by Ngs1022 »
Re: 83 Silverado question
« Reply #1 on: June 19, 2015, 01:08:27 am »
It's called a turn signal lever.  But, looking at the pic, the problem is more likely a broken turn signal switch inside the column.
Offline Ngs1022
Re: 83 Silverado turn signal assembly question
« Reply #2 on: June 19, 2015, 01:11:33 am »
Yes the lever is fine its the switch inside...i cant seem to find one online... Can u help?
« Reply #3 on: June 19, 2015, 01:24:33 am »
Offline Ngs1022
« Reply #4 on: June 20, 2015, 12:36:13 am »
Ok i got the part today. Are there any articles pics or videos showing how to remove my '83's steering wheel and install this part successfully??
Offline roundhouse
« Reply #5 on: June 20, 2015, 07:30:05 am »
You will need a steering wheel puller and another tool to remove the round disc with all the notches in it that locks the wheel from turning when you take the key out
Once you get the wheel off and the lock disc off there is I think 3 screws holding the plastic assembly in
Fishing the wire down the steering Collumn is the hardest part
Easiest way is to clip the connector off the lower end and tape a string or wire to it
The use that string to pull the new one back down
I'm sure there is some good vids in YouTube
Offline Ngs1022
« Reply #6 on: June 20, 2015, 11:07:14 am »
Is this a special tool to remove the round disk or ? I found s steering wheel puller, just need to kmow if i need to buy any more special tools
Offline blazer74
« Reply #7 on: June 20, 2015, 03:27:55 pm »
Offline frotosride
    • WFO CONCEPTS
« Reply #8 on: June 20, 2015, 08:43:16 pm »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=12525.0
I noticed the tilt lever so thank nknwill give you more info than you need but the rest may come in useful later.
Offline Ngs1022
« Reply #9 on: June 21, 2015, 02:05:53 am »
Thanks guys!
Offline roundhouse
« Reply #10 on: June 21, 2015, 09:07:33 am »
disc remover is different from wheel puller
