Author Topic: New member with wheel and tire question  (Read 6017 times)
Offline Bigrob1612
« on: June 19, 2015, 05:05:22 pm »
Hey everyone new to the site but not new to the forum world. I have a 1979 C10 SWB. I was curious what the widest wheel and tire setup I can run is before I have to start messing with the suspension and tubbing the rear. I've researched and found that the majority of the guys run 15x10 with a 5" bs. Can anyone confirm that this is the widest wheel setup possible for stock suspension setup.
Thans in advance.!
Offline Emoo99
Re: New member with wheel and tire question
« Reply #1 on: January 10, 2020, 10:16:06 pm »
I just got 15x10 with 5.5 backspacing.. just fitted the rims only today with no tires and  they should be almost perfectly centered with 1/4in spacers.. I’ll be able to for a 12.5 tire if I cut off the bolts that stick out of the wheel tubs on the inner fender.. I’m mounting 32/11.50 15s on.. but I could fit a 33/12.50 15 if I wanted.
Truck is 2wd 77 blazer
