Author Topic: 90 suburban headlights swap c10 83  (Read 4120 times)
Offline malrubaei
  • New Users
« on: July 01, 2015, 03:24:35 pm »
Hello guys. Im new here
my question is if i order a 90 burb headlight assembly will i get the adjustment screws and springs with it.
Im preparing a part list to give 83 c10 a face lift but junkyards around me dont have those old trucks so i have to get my parts online i need sompe help that i got everything covered.
Thanks
Sent from my SM-N9005 using Tapatalk
Offline timthescarrd
Re: 90 suburban headlights swap c10 83
« Reply #1 on: July 01, 2015, 03:26:40 pm »
What you get depends on where you are ordering from.  I believe to switch to the 88+ style front, you need the readiator support, headlamp assemblies, grill, and wiring.  It's quite a few parts
Offline malrubaei
  • New Users
« Reply #2 on: July 01, 2015, 04:16:29 pm »
My list now got:
. Radiator support
. 3 bezel pieces
. Turn signal assemblys
. Headlight assemblys
Still looking for the right wiring connectors and wondering about the adjustment screws and springs
Would be great if someone can share a pic of the connectors i will need
Offline square81
« Reply #3 on: July 03, 2015, 08:51:15 am »
For wiring you can get a doner harness from a suburban, blazer, jimmy of same years. Or if you have the stacked headlight set up now. You can get the headlight pigtails and wiring it in. I used a stacked headlight harness and the suburban harness and it worked good. As for springs and screws. Try auto part stores. I got my springs from gm parts. Took awhile but got them. I think early to mid 90's full size gm vans had the same parts and pieces your looking for too.
