Author Topic: Cab Mounts- Energy or ????  (Read 5871 times)
Offline TPI84GMC
« on: July 06, 2015, 07:34:27 pm »
Hello all. I am looking at replacing my stock rubber cab mounts on my '84 short bed standard cab. Lowered spindles and springs up front. Flip shackles and hangers in the rear. Anyone have any reviews on the Energy Suspension poly bushings? Any other brand better?
http://www.energysuspensionparts.com/3.4116
« Last Edit: July 08, 2015, 09:25:01 am by bd »
Offline SkinnyG
  • Reducing resale value since 8-track days
Re: Cab Mounts- Energy or ????
« Reply #1 on: July 07, 2015, 09:39:55 am »
I did Energy Suspension cab mount bushings on my C10.  While it made the truck feel a whole lot tighter and new, it also transferred a whole lot of noise/vibration/harshness into the cab.  Mind you, I have all poly suspension mounts as well as all poly motor/trans mounts.  And 1-ton springs front and rear.
I kind of regret the poly cab mounts.  But I'm getting old and feeble.
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
Offline LTZ C20
« Reply #2 on: July 08, 2015, 01:22:18 am »
Energy suspension is pretty much the best. I did their body mounts, no complaints here at all, ride quality is good, overall smoothness is good. I'm happy. I plan on using their suspension and steering bushings also.
LTZ Cheyenne C20
Offline TPI84GMC
« Reply #3 on: July 09, 2015, 01:28:39 am »
Thanks guys! I'll go with Energy. Truck rides like crap with the drop anyway so might as well stiffen it up!
Offline LTZ C20
« Reply #4 on: July 09, 2015, 01:58:28 am »
Welcome. If it rides stiff now, then it will be increased with the new mounts. If the ride is more being in a boat then new mounts will stiffen it up and give it some strength.
LTZ Cheyenne C20
Offline 84Silverado4x4
« Reply #5 on: July 10, 2015, 04:45:43 pm »
I would not use the stock rubber replacement from a place like oh say  .  Less than a year after installed mine are all cracked up and look like crap.  Maybe the originals were much better but I think I would try the energy ones if I did it over.
84 Silverado Reg Cab Shortbox 4x4
4" lift with 35's
5.3 vortec, 4l60e, np208, dana44, GM 12 bolt
