The Highs (Raising/Lifts)
How big is my lift?
Topic: How big is my lift? (Read 19404 times)
rugbychevyguy
Re: How big is my lift?
Reply #15 on:
July 12, 2015, 09:51:52 am »
So i have a k20 front and k30 rear? Haha.
It was 14" from top of rear axle to bottom of frame. What are some good 36s that would fit my wheels?
Sent from my SM-G920P using Tapatalk
timthescarrd
Reply #16 on:
July 12, 2015, 12:25:51 pm »
some K20s came with the 14bolt FF rear end, and some people have swapped K10 10-bolts to 8 lug, If you use 3/4 ton springs, it'd be safe to say you have the same capacity as one of the heavier K20s
Reply #17 on:
July 12, 2015, 03:03:58 pm »
yeah what tim said. more than likely you have ¾ ton set up. 1 tons also can have other rear ends like the dana 70.
super swampers are good but their life is very limited due to the tire compound being so soft. but what are your intentions on this truck? do you plan on light off road or you just want that "cool" factor?
rugbychevyguy
Reply #18 on:
July 14, 2015, 10:42:17 am »
I want the cool factor but i also like to go mudding so maybe even good 35s?
How big is my lift?
