Author Topic: How big is my lift?  (Read 19403 times)
Offline rugbychevyguy
How big is my lift?
« on: July 08, 2015, 10:48:51 am »
I have an 84 k10 that was already lifted when i purchased it, i want to get new shocks and first need to find out how much it was previously lifted. I know i have to measure from frame to axle but i don't know what the original height was. Any suggestions on where to find that and any suggestions on type of shocks?
Thanks y'all
Sent from my SM-G920P using Tapatalk
Offline Jason S
Re: How big is my lift?
« Reply #1 on: July 08, 2015, 11:24:56 am »
Quote
Do you have lift blocks in the rear?  If so, you can measure the block height.  Can you post any photos?
« Reply #2 on: July 08, 2015, 11:41:36 am »
I assume this is what you wanted
Offline timthescarrd
« Reply #3 on: July 08, 2015, 01:12:48 pm »
What size are those tires?
« Reply #4 on: July 08, 2015, 02:47:48 pm »
not a k10 with 8 lug rims
« Reply #5 on: July 09, 2015, 10:47:28 pm »
It's vin says k10 but has a k30 rear end
« Reply #6 on: July 10, 2015, 12:07:03 am »
the front axle is only k20
« Reply #7 on: July 10, 2015, 01:25:31 am »
How can you tell?
Offline Don5
« Reply #8 on: July 10, 2015, 01:40:43 am »
It has an 8 lug front end with, it looks like, small hubs. That means it is not a Dana 60 1 ton front end. :) The rear end is a 8 lug Fully floating 14 bolt rear end. What size tires are on it? Can you measure from the top of the rear axle to the bottom of the frame at the bump stop? My truck is a 1/2 ton with a 6 inch lift and that distance is 17 inches I believe. It looks like a 2 1/2 inch add a leaf on the rear too.
« Reply #9 on: July 10, 2015, 11:02:06 am »
Its 14in from rear axle to frame and my tires are 285/75r16
« Reply #10 on: July 10, 2015, 12:55:53 pm »
x2
dana 60 hub is about 4". there are dana 44 that look similar to it but as you can see compared to yours theres a big difference. aint no biggie unless you plan on mudding with 38+" tires
« Reply #11 on: July 10, 2015, 04:24:17 pm »
285/75/16 tires are just over 32.5" tall (equivalant to a 33x11.5). Based on that, I would say you have a 2.5" lift front and rear
« Reply #12 on: July 11, 2015, 12:42:17 pm »
How much do you think it would cost to raise that to a 4" lift? And if i did that what size tires would look right?
« Reply #13 on: July 11, 2015, 12:44:04 pm »
Irish, i know it is definitley a k10 front end i was just curious how you could tell from a picture haha. That is really cool you can do that and thank you for the information!
« Reply #14 on: July 11, 2015, 03:06:27 pm »
lol not a k10 (for say) the only difference in a k10 6 lug and k20 8 lug front end is from the hubs out (year respective).
now this part is a complete guess, but if 33s fit like that you should be good with 36 its only 1.5" on each side. i would think the lift is MAYBE close to 6" if we could get a list of measurements together from top of axle to frame (not bump stop) we could make a chart.
