Author Topic: Starter wiring from bulk head  (Read 16080 times)
Offline jhiggin
« on: July 10, 2015, 03:34:50 pm »
So my truck was on its 3rd motor when I got it ( it's an 81 c10 that came with a 350 conversion diesel which obviously blew up so pawpaw put in a 6.2) now with that being said he definitely rigged a lot of the wiring and one of the things that ended up rigged was the ignition. Basically the actually key ignition works for everything but the starter ( it had a momentary switch to start it). My question is does anybody know where exactly on the bulk head the original wire was to go to the starter?
Re: Starter wiring from bulk head
« Reply #1 on: July 10, 2015, 04:11:26 pm »
do you have cut wires at the firewall? one thing to do is have a friend turn it to start and use a volt meter to see what wires only have 12v when the key is turned to start
Offline jhiggin
« Reply #2 on: July 10, 2015, 04:40:57 pm »
you know that's not a bad idea. I'll try that and see what I come up with
Offline hatzie
« Reply #3 on: July 11, 2015, 09:24:59 am »
The 1981 wiring diagrams are in the back of the 1981 factory service manual that I scanned and Chris hosted on this site.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=25639.0
The "start" wire is usually purple.  The FSM will show the exact position in the firewall bulkhead plug.
From orbit on my Android.
« Reply #4 on: July 11, 2015, 04:10:18 pm »
this is the same thing hatzie posted but edited a little to help read it http://forum.73-87chevytrucks.com/smforum/index.php?topic=30115.0
Offline jhiggin
« Reply #5 on: July 13, 2015, 10:06:26 pm »
This is a gild mine!! Thank you all for the help!
Offline hatzie
« Reply #6 on: November 25, 2015, 07:13:02 pm »
Nice work.  Better readability.;D
