Author Topic: Manual to automatic swap  (Read 2639 times)
Offline pierce8468
« on: July 22, 2015, 08:48:45 am »
I recently purchased a 85 c30 dual wheel crew cab that has a 350 with manual trans in it.  I also have a complete 88 c3500 single cab dual wheel 6.2 diesel with automatic trans.
I Would like to know if I can swap the trans from the 88 diesel and bolt it up to the 85 c30 gasser?    If so can i use the torque converter from the diesel as well as the flex plate, or will I have to replace them?   Another question I have is will the rear be the same bettwen both trucks or will I have to swap them out as well?
Re: Manual to automatic swap
« Reply #1 on: August 02, 2015, 07:15:54 am »
im going to say nothing will bolt up, the part numbers on the flywheel dont match up on each engine neither does the torque converter
