Author Topic: cab swapping?  (Read 8841 times)
Offline 79c10junkie
cab swapping?
« on: April 01, 2004, 10:26:00 am »
hey.guy's. I have a 79 c10.The cab and bed are eaten up w/ cancerous rust.:\ Will an early 80's model scottsdale cab and bed mount to my frame. The body looks identical to myc10.Just wondering if this has been done and what problems I may encounter.Also the scottsdale has square head lights,the c10's are round.Will this be a problem?Thanks in advance.
                 David
Offline roundedline
Re: cab swapping?
« Reply #1 on: April 01, 2004, 10:55:00 am »
Are you just swapping the cab with what is currently in it, or JUST the cab and putting your old stuff in it.  First, check to make sure you are legal before you start.  It isn't legal to swap VIN's.  Second the '81-up cab will swap you just need to use the frame specific cab mount bushings.
If you are swapping interiors, the will be some issues to address.  The 73-80 front clip will bolt to the '81-up cab with no problems.  If you were swapping clips from a 73-80 to an '81-up there would be some changes to be made.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline cochise42
Re: cab swapping?
« Reply #2 on: April 02, 2004, 01:10:00 am »
What would be the changes for swapping clips from a 73-80 to an '81-up
Offline 73K20
Re: cab swapping?
« Reply #3 on: April 02, 2004, 07:42:00 am »
Scroll through the previous posts here, there is lots of info on swapping cabs from those years.
1973 K20 - 350/465/205
Offline roundedline
Re: cab swapping?
« Reply #4 on: April 02, 2004, 09:43:00 am »
Putting a 73-80 clip on an 81-up requires no changes.  Putting an 81-up on a 73-80 is where the changes occur.
BTW, did you see the replies to you post on these questions?  The were answered there also:  pub158.ezboard.com/f7387c...=167.topic
Project Su
Jimmy 2WD Project
Edited by: roundedline at: 4/2/04 9:45 am
Offline 79c10junkie
Re: cab swapping?
« Reply #5 on: April 02, 2004, 09:33:00 am »
What is the front clip?The only body work I've done is changing the fenders and hood ,and also a little rust repair to my door,which has all been done to the 79 c10 I have owned for 2 1/2 months.So I'm not as educated as you guys yet.Any help is appreciated.
                         Thanks,
                                    David
Offline cochise42
Re: cab swapping?
« Reply #6 on: April 02, 2004, 05:41:00 pm »
Reason I wrote if there were any mods to the front clip is that I have an 1980 c10 shortbed step side. and I just got a 1983 c20 which I want to take the 83 front clip and put it on my 80 stepside. and just wanted to know if everything was going to fit I know I will have to mod the cowl
Offline roundedline
Re: cab swapping?
« Reply #7 on: April 02, 2004, 07:32:00 pm »
Front clip.  EVERYTHING from the front doors forward.  Fenders, inner fenders, core support, hood, etc...
Project Su
Jimmy 2WD Project
