Author Topic: 2 barrel- 4 barrel 305  (Read 14101 times)
Re: 2 barrel- 4 barrel 305
« Reply #15 on: July 29, 2015, 09:13:30 pm »
Im not sure but I think I have to put the # 1 piston on tdc then place the distributor back in?
Sent from my XT1058 using Tapatalk
Yes you got this... but make sure it is on the power stroke.  It is easy enough to be 180° out
Offline blueboy86
« Reply #16 on: July 29, 2015, 09:27:04 pm »
Alright. So are all of my stock bolts gonna work with the Holley intake? And is it OK to use the same thermostat?
Offline blueboy86
« Reply #17 on: July 29, 2015, 09:31:24 pm »
Here's my list so far..
plugs
Wires
Hei dist. Cap
Intake gaskets
Carb gaskets
Valve cover gaskets
Kickdown bracket
Fuel filter/line
Air filter
Think I'm forgetting some things.. What do you think?
« Reply #18 on: July 29, 2015, 10:08:01 pm »
sounds like a pretty good list
