Author Topic: 2 barrel- 4 barrel 305  (Read 14127 times)
Offline blueboy86
« on: July 27, 2015, 01:29:36 pm »
Ok so im swapping my 305/700r4 from a 2 barrel setup to a 4 barrel setup. I have a Holley dual plain aluminum intake and an edelbrock 600cfm carb. Can someone help me out with this swap? I need to know what linkage I need for the transmission. Also do I need any other brackets?
Re: 2 barrel- 4 barrel 305
« Reply #1 on: July 27, 2015, 09:14:20 pm »
My only input is that the TV cable be set perfectly with whatever carb you choose.  Obviously the 2 bbl never came with a 700R4 so whatever was done to keep that from frying the transmission that needs to be duplicated.  A picture of your current setup would be helpful to see the current hookup.
Offline blueboy86
« Reply #2 on: July 27, 2015, 10:28:59 pm »
I will get some pictures soon. And I think the previous owner swapped in the rebuilt 700r4. Along with a motor craft 2 barrel. Which is slightly rigged up. I am using the edelbrock 1405. So where exactly does the TV cable hook up on the carb? And how would I set it up perfectly? Thanks for the input BTW!
« Reply #3 on: July 27, 2015, 10:41:04 pm »
I don't have a 700R4 in any of my collection for pictures but there are plenty of members here that will help you out.  Because of my bad experience with 700R4's I stay away from them.  Currently my 2 automatics are TH400's and my other 3 are stick shifts.
Offline blueboy86
« Reply #4 on: July 28, 2015, 07:40:32 pm »
I took some pictures.
Sent from my XT1058 using Tapatalk
Offline blueboy86
« Reply #5 on: July 28, 2015, 07:41:02 pm »
Offline blueboy86
« Reply #6 on: July 28, 2015, 07:41:28 pm »
Offline blueboy86
« Reply #7 on: July 28, 2015, 07:43:48 pm »
I'm assuming the bottom cable is the TV cable. As you can see the connection is welded on the the carb linkage.
« Reply #8 on: July 28, 2015, 10:11:42 pm »
Yes, it is a wonder it worked and your trans is OK.  Some one will post the correct bracket for a quadrajet set up eventually.
Offline Sscwebb
« Reply #9 on: July 29, 2015, 04:57:57 pm »
http://www.tvmadeez.com/1406_cam/
Go to bowtieoverdrives.com, good place to start.  You will burn up your transmission if not set up correctly.
Offline blueboy86
« Reply #10 on: July 29, 2015, 07:51:58 pm »
Thanks. So TV cable is really important lol....Now for the intake.
Offline blueboy86
« Reply #11 on: July 29, 2015, 07:54:40 pm »
Do i have to remove the distributor completely? Or just the cap?
« Reply #12 on: July 29, 2015, 07:59:34 pm »
Distributor has to be removed.  When you take it out you will see why.
Offline blueboy86
« Reply #13 on: July 29, 2015, 08:15:21 pm »
Yeah that's what I thought. Will i have to reset my timing afterwards?
Offline blueboy86
« Reply #14 on: July 29, 2015, 08:16:39 pm »
Im not sure but I think I have to put the # 1 piston on tdc then place the distributor back in?
