Author Topic: Saddle tank fuel pick ups  (Read 5967 times)
Offline rugbychevyguy
« on: July 27, 2015, 04:20:05 pm »
Any suggestions on how to clean, test and repair these to make the useable. I want to get new gaskets and cleaner boot things.
Sent from my SM-G920P using Tapatalk
Offline timthescarrd
Re: Saddle tank fuel pick ups
« Reply #1 on: July 27, 2015, 04:40:33 pm »
I know this doesn't really answer your question but you can buy whole new ones at most parts stores for 50-60 USD. With as ruste as those are, I'm not sure I'd trust them.
Testing them would be to check the Ohms as you move the float from the bottom to top 0 empty 90 full (one lead on that single wire the other to a good ground and don't touch and of the metal while you're testing it.
By boot thingy I assume you mean that long black mesh at the bottom of the pickup tube?  I've heard that called a sock, a sleeve, or a filter.  It basically just prevents large particles from going into the tube.  Those get brittle with age, I'm not sure where you would get new ones.
