Author Topic: Horn  (Read 3216 times)
Offline pneuner750
Horn
« on: July 27, 2015, 04:23:39 pm »
Does anyone know if a 86 c-20 has a horn relay? If so where is it?  What color is the horn wire coming from the column?
Thanks!
Sent from my SM-P900 using Tapatalk
Re: Horn
« Reply #1 on: July 27, 2015, 05:14:51 pm »
All of the square bodies were produced with horn relays.  The '86 horn relay is mounted in the "Convenience Center" - a black plastic chassis mounted under the dash against the firewall, directly above the accelerator pedal.  The 'Convenience Center' also holds the key/seatbelt warning buzzer and hazard flasher.
Offline pneuner750
Re: Horn
« Reply #2 on: July 27, 2015, 10:23:00 pm »
Thank you! !
