Author Topic: 86 Engine everything😂  (Read 4045 times)
Offline CDog86
  • All Alaskans arent Eskimos, no we don't ride bears
« on: July 28, 2015, 01:09:23 pm »
I have an 86 K10 that overheated yesterday... Reason being my transmission won't shift after 35mph (into third or whatever it would be). This being said I know fluid level is good I recently replaced and have the TV cable set up and was working fine the past couple months but all of a sudden it's like it slips out of gear. After it slips out rpms just go up as you rev the engine but it won't go anywhere until slowing down enough for it to downshift back into gear an then the process repeats trying to go over 35?
Offline fitz
Re: 86 Engine everything😂
« Reply #1 on: July 28, 2015, 01:44:41 pm »
I'm guessing your 700R4 is junk.
« Reply #2 on: July 28, 2015, 03:16:31 pm »
Lost fluid pressure and/or burned the 3-4 clutch pack.
Offline CDog86
« Reply #3 on: July 28, 2015, 03:34:24 pm »
I'm guessing the 3-4 burnt up because it is junk😂
Offline CDog86
« Reply #4 on: July 28, 2015, 03:42:31 pm »
Nother question, what caps or plugs do I need to remove all the smog stuff
« Reply #5 on: July 28, 2015, 04:14:03 pm »
It could have been the result of a poorly designed input drum (junk), an internal seal leak (normal wear), improper TV adjustment, or a myriad of other causes.
The 700R4 is an excellent transmission when properly built and maintained.
