Author Topic: 76 and 78 doors  (Read 14935 times)
SS
  • Guest
76 and 78 doors
« on: October 05, 2001, 12:26:00 pm »
Can someone tell me what the difference is, if any, between the doors off a 76 p/up and a 78 p/up?  I want to swap them out, but have heard it will not work.
Offline bigblock73
  • Yeller
Re: 76 and 78 doors
« Reply #1 on: October 05, 2001, 11:47:00 am »
73-76 doors are identical but are different from 77-?? doors.  I found this out the hard way when i bought 77 doors for my 73 (the 77's were about $50 cheaper per door at the time).  The main differences between them, at least that I'm aware of, is that the window tracks are different and your windows wont work in the 78 doors.  If you want to run the 78 doors with the 76 guts you will have to swap them by welding the old tracks into the new doors.  If you do this then your window cranks wont stick out far enough, you can only fix that by welding an extension on the crank or put power windows in.  Your door panels will also not work.  If you are going to swap a complete door with everything in it and on it from the 78 then you will be OK and everything will be fine, otherwise you are in for a little mess.
Jeff
'73 swb 2wd
73-87.com
Offline captkaoscustoms
Re: 76 and 78 doors
« Reply #2 on: October 24, 2001, 09:35:00 am »
Here are the differences:
The mounting of the power or manual regulator.  73-76 didn't have power windows.  The length of the shaft for the window crank, the door panel mounting.  77-91 doors are the same.
73-76
77-91
Offline 1979blazer
awsome
« Reply #3 on: January 06, 2002, 07:51:00 pm »
thats awsome that you added pictures to that answer
Edited by: 1979blazer at: 4/21/04 11:55 pm
A picture is
« Reply #4 on: March 18, 2002, 01:45:00 pm »
Like they say, a picture is worth a 1000 words...  Your welcome.  A while back I had to answer this question alot, so I just took the pics to explain it.
