Engine/Drivetrain
75 3/4 ton gmc sierra sm 465 bell housing
Topic: 75 3/4 ton gmc sierra sm 465 bell housing (Read 4306 times)
seventy5GMC
August 12, 2015, 12:44:41 am »
Hello
wondering if anyone can help, my bellhousing for my sm465 has 4 main boltholes to attach the tranny,Ive got the bellhousing bolted to an engine stand with the tranny attached. Theres a fifth threaded hole on the very top of the bellhousing which I cannot remember what bolts to it. this top hole sits above the trans so I'm guessing is part of the wiring harness bolted to this?
any help is appreciated.
thanks
Re: 75 3/4 ton gmc sierra sm 465 bell housing
August 12, 2015, 12:11:21 pm »
You got a picture?
zieg85
August 12, 2015, 12:38:19 pm »
If the picture is what you have it is the newer dual pattern bell housing from a 81 on up
seventy5GMC
August 13, 2015, 12:59:18 am »
I have what is called GM #6263756,,,it has 5 holes,but my sm 465 has only 4,there's and extra hole at 12 oclock. its a through hole thats threaded, ??
August 13, 2015, 01:21:06 am »
That PN is for a 12" clutch/pressure plate for Trucks trans. You don't need the 5th hole on the SM465.
seventy5GMC
August 13, 2015, 01:37:24 am »
thanks for the reply! is it best to fill the hole with a bolt anyway?
August 13, 2015, 01:44:37 am »
I would probably plug it.
Engine/Drivetrain
