Author Topic: 84 k10 weak brakes  (Read 4447 times)
Offline rugbychevyguy
84 k10 weak brakes
« on: August 12, 2015, 06:52:45 pm »
My brakes have recently been really weak. Don't know how to explain it but it feels uneasy. Any suggestions as to whatbi could do? There is brake fluid and i do not have power brakes.
Sent from my SM-G920P using Tapatalk
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: 84 k10 weak brakes
« Reply #1 on: August 12, 2015, 08:32:51 pm »
Well, check the hoses, they could be expanding, not putting the pressure where it needs to go. Also check pad wear-too much wear, pedal needs to travel farther for same braking.
You can also check and make sure none of the hardware broke, that can cause a bigger issue if a shoe is just flopping around
A leak is still possible- where there is a leak, there is air,air means softer brakes(could be very slow, so fluid may not look like it is receding, especially if it is pulling air back in)
 1986 Chevy K30(under repair)
Offline Breadfather
  • A Z CARDINALS!
« Reply #2 on: August 12, 2015, 10:31:46 pm »
Could be time for new rear shoes.  If they are almost gone or you don't reverse that often they may need to be manually expanded.  Rear brakes being low make a big difference.
1977 K10 Scottsdale, Deluxe Sport Package, SB 400, TH 350, Rusty Black.
« Reply #3 on: August 13, 2015, 07:13:38 am »
i would check the vacuum line and check valve on the booster. unplug the check valve and see if your engine rpms pick up while the engine is running
« Reply #4 on: August 13, 2015, 11:20:17 am »
He said no power brakes
« Reply #5 on: August 13, 2015, 11:32:52 am »
lol i was thinking he was saying it feels like he has no power brakes
