Author Topic: Need help finding a part  (Read 2923 times)
Offline Eastonfrench
« on: August 13, 2015, 10:32:24 pm »
I have a 1980 Chevy k10. I recently noticed a small leak from the front output shaft, so i replaced the seal. when i was putting everything back together, i forgot to put the metal washer on, and managed to mangle the rubber splined washer that goes on the end of the front output shaft. My front output shaft is a 30 spline, and i need the new rubber washer.
I found one online but they are discontinued. I ordered a seal kit and the kit only came with 32 spline washers, which will not work. I also tried a Pick and Pull yard, but all the transfer cases had been taken. I would love to find someone with a bad transfer case that would still have this washer on it.
Anybody know where i could find this piece? my truck is stuck in the garage until I can find one!
I've attempted to attach an image as well.
1980 K10 - 350-Quadrajet-TH350-NP203
