Author Topic: Move a steering column?  (Read 4820 times)
Offline mrjata
« on: August 13, 2015, 11:05:51 pm »
Is there way to move the steering column away from my big belly in an '83 c10 with tilt?  I would love to move it closer to the dash like a normal truck.  Not much room in the cab as is.
Re: Move a steering column?
« Reply #1 on: August 13, 2015, 11:12:33 pm »
Offline mrjata
« Reply #2 on: August 24, 2015, 10:56:30 am »
When I get time, I am going to look into moving the whole column forward rather than diddle with the seat.  I think I can do more there, well, it looks good in my head right now.
Thanks for the options.
Offline roundhouse
« Reply #3 on: August 26, 2015, 06:40:08 am »
Seems doable
Just need to move the mount  on the column where it bolts to the dash
I don't remember if it is welded or bolted to the Collum
Shortening the shaft under the hood should be pretty easy
The clamp on the firewall shouldn't be an issue
