Author Topic: Shackle Flip Awesomeness  (Read 5608 times)
Offline enaberif
« on: August 18, 2015, 11:28:39 pm »
No I don't have any progress pictures as I'm the only person doing it with a limited schedule and trying to get as much done. People often wonder the results of doing a shackle flip with old springs. My truck is 40 years old and has what I believe to be the stock springs. I am in the process of installing a 4" lift and went with a ORD shackle flip on the rear.
For now these are rough measurements from center of axle to bottom of fender opening. I know somewhere in here is stock measurements from top of axle tube to the bottom of the frame so if someone who reads this could provide that info I could do those measurements.
Measurements Before/After:
Difference:
Offline 86HighSierra
Re: Shackle Flip Awesomeness
« Reply #1 on: August 19, 2015, 04:42:28 pm »
I have an 86 sierra with a 17 year old spring 2" lift kit. I did the ord shackle flip kit with super shackles and kept the rear lift springs and did new 6" front springs. Not done building project but i was amazed that the rear is sitting level with ftont end . When the motor goes in, the front will be alittle lower. ( i think it looks better than the backend sagging). So I myself like the shackle kits
Just my 2 cents
Would like to see photos when u are done
Jd
« Reply #2 on: August 19, 2015, 04:50:15 pm »
once youre done add you info Here please
Offline enaberif
« Reply #3 on: August 19, 2015, 04:59:41 pm »
Will do! I will also grab the axle tube to frame measurements as well once I get on some flat ground.
