Author Topic: Broken Hazard Switch - Can't find a new one!  (Read 15838 times)
Offline Thundergun
« on: August 19, 2015, 10:27:34 pm »
Hey Guys - I have an 85 k10.
The physical switch that you pull out and push in to activate the hazard (or emergency) flashers is missing. It looks like a small cylinder and it's located on the lower right hand side of the steering column.
I CANNOT for the life of me find a new one, at the parts store or online.
Does anyone have a part number or a recommend where to get one?
Local junkyards don't have one :(
Thanks!!
1985 K10 Shortbed, 6" Superlift, 33x12.5x15" tires, 100% bad, '87 fuel injected 350 (i think)
Offline timthescarrd
Re: Broken Hazard Switch - Can't find a new one!
« Reply #1 on: August 19, 2015, 10:49:34 pm »
I think I've seen em in the Dorman/Help stuff at O'reilly but can't find it on their website, it's really nothing more than a button that screws in to push in/pull out.  I bought this column dress kit that came with a fancy screw, that's what I'm using
http://www.amazon.com/gp/product/B000CSQY0K?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
« Reply #3 on: August 19, 2015, 10:53:11 pm »
If you are looking for the button, screw, spacer and spring you are probably going to have to go to a pick and pull and bring a phillips screwdriver.  Any GM steering column up to 1992 or so would be the same
Offline Thundergun
« Reply #4 on: August 20, 2015, 11:02:52 am »
Thanks for the info guys. I'm actually looking for the external piece as well as the internal switch that makes contact. I think i found one at the local salvage yard, fingers crossed. it's been a pita.
« Reply #5 on: August 20, 2015, 11:34:34 am »
Best of luck, that internal piece is a part of the switch and may not be replaceable by itself.  New switches are not that much but at least you can get the outside parts that you need.
« Reply #6 on: August 20, 2015, 03:10:21 pm »
repo $10
ac del $25
Offline Thundergun
« Reply #7 on: August 20, 2015, 09:40:14 pm »
awesome thanks Irish.
I got that part today. But now i need the actual switch inside the column that these parts activate.
Any thoughts?
Offline Thundergun
« Reply #9 on: August 21, 2015, 06:08:17 pm »
Okay, so that part contains the switching mechanism for the hazards knob, i assume.
Darn. That is not something i am familiar with installing.
Thanks tho!
Online bd
« Reply #10 on: August 21, 2015, 08:13:21 pm »
How-To: Fixing a Sloppy GM Tilt Column shows step-by-step teardown and assembly to replace the turn signal switch along with the necessary tools.  Just follow along as far as the switch then reverse the order.
Offline Autonutz
« Reply #11 on: August 24, 2015, 12:35:10 am »
repo $10
ac del $25
$25 for 2 pieces of plastic, a spring and a screw....
If that poor kid in China found out the markup on that he'd probably commit suicide lol
Offline Thundergun
« Reply #12 on: August 24, 2015, 10:22:22 pm »
Awesome thanks! i love this forum!
